Tf suspension bolt torque
Tf suspension bolt torque was created by pete l
Posted 3 years 8 months ago #195310
Hi all. Never been here before, just found it so please be kind ๐Ÿ˜
I've just swapped my tf suspension for the soft ride shocks. Everything went well. But I'm having big doubts about the big bottom shock bolts, it says to torque them up to 100 nm. That doesn't seem very tight to me. It's the same as a wheel nut!!!!.ย
Have I miss understood something? People write about using a breaker bar etc on the bolt.ย
Any info and thoughts???ย
Pete.ย
by pete l
Replied by talkingcars on topic Tf suspension bolt torque
Posted 3 years 8 months ago #195311
Hi and welcome to the forum
IMHO 100nm is plenty. More important is to make sure you fit the uprated lower bolts, Rimmer Bros do all 4 for a reasonable price. I have had both rears fail, first took out the CV boot, second took out the CV boot and a brand new tyre that had done 3 miles!
James
Replied by pete l on topic Tf suspension bolt torque
Posted 3 years 8 months ago #195313
Hi James,ย
Thanks for your reply. I've had the car from new, never had any suspension work done on it and when I removed all 4 bolts they were perfect, no sign of damage, not bent or anything.ย
Did yours fail after having work done on the suspension??ย
Pete.ย
ย
by pete l
Replied by mowog73 on topic Tf suspension bolt torque
Posted 3 years 8 months ago #195319
Wheel nuts is 75 Nm. 100 Nm is a lot!. There are bolt torque charts on the internet, based on the bolt diameter and the grade of the bolt, helpful if you can't find the torque setting in the workshop manual.
[size=10pt]Mark[/size]
95 MGF
by mowog73
Posted 3 years 8 months ago #195320
Hi Mark, in my handbook, my wheel nuts for my 16 inch wheels should be tightened to 100 nm.ย
by pete l
Replied by David Aiketgate on topic Tf suspension bolt torque
Posted 3 years 8 months ago #195323
There was an advisory from MGR that revised the 16" wheel torque upwardsย  to 100nm.ย  I cant find the date of the advisory,ย  but consequently I've always torqued my wheels to 100nm regardless of wheel size. After all it is the same stud and nut.
There were some instances of wheels becoming loose at 70nm( probably down to inaccuracy in the torque wrencn) and I think the advisory was purely precautionary.ย ย
Last Edit:3 years 8 months ago by David Aiketgate
Last edit: 3 years 8 months ago by David Aiketgate.
Posted 3 years 8 months ago #195326
The uprated bolts, what's different about them? Are they tightened to a higher torque?
Should thread lock be used? MG rave for the TF doesn't mention it.ย
Pete.ย
by pete l
Posted 3 years 8 months ago #195337
Pete
The car should have been recalled at some point to have the bolts replaced.
James
Posted 3 years 8 months ago #195342
The recall was for the early TFs because of torque relaxation. Mine is an early 2005, MG Rover knew how to tighten the bolts at this point ๐Ÿ˜
Can I tighten them a bit more than specified? Just to make sure.ย
by pete l
Time to create page: 0.559 seconds
