Expansion caps, real OEM or not.
As this is a continuing theme on the forum, I thought a bit of scientific examination was called for.
I bought a genuine (Rimmer bros) expansion cap and another eBay bargain, which was half the price of Rimmers.
Here they are together.
And the insides. NOW THEN:- Which is genuine and does it make any difference?
I tested both with my pressure tester setup.
Results:- 1 held around 14- 15 psi,
1 held around 6 psi.
Last Edit:3 years 8 months ago
by David Aiketgate
Last edit: 3 years 8 months ago by David Aiketgate.
The following user(s) said Thank You: Raccoon
Replied by David Aiketgate on topic Expansion caps, real OEM or not.
Posted 3 years 8 months ago #195378David
The following user(s) said Thank You: mowog73
- sworkscooper
Replied by sworkscooper on topic Expansion caps, real OEM or not.
Posted 3 years 8 months ago #195380
Aay up David . Ive just bought one of those caps from Rimmers for our MPI classic Mini and it came in a SIAC bag . My question is, which one of yours failed ? Since I retired from the motor trade I do find that I miss the equipment like your tester for cooling systems. Took it all for granted while I was working . I might have to invest in one of those if the caps are of such bad quality.
John
John
by sworkscooper
Posted 3 years 8 months ago #195381David
by David Aiketgate
Posted 3 years 8 months ago #195382
This is the pressure test kit I have.
You do need to make up a threaded adapter to test caps as opposed to testing the entire system.
- sworkscooper
Posted 3 years 8 months ago #195383
I might have to invest in one. 👍
by sworkscooper
Thanks David for doing this little test, truly surprising. I'm glad I've always paid the extra for a genuine cap from Rimmer.
[size=10pt]Mark[/size]
95 MGF
Last Edit:3 years 7 months ago
by mowog73
Last edit: 3 years 7 months ago by mowog73.
If you don’t have the adaptor to test caps you can use two coolant tanks joined together with a couple pieces of hose. Put the cap under test on one tank and something like the Laser pressure tester on the other tank and pump away.
Nigel
Nigel
by countax
Time to create page: 1.024 seconds
