Re:Re:Silencer
Many thanks for any thoughts you might have.
Steve wrote: If you buy one it may as well be stainless as the price difference is worth the long life, if its not your daily drive then you are more likely to get condensation in the internal of the exhaust box and tend to rot so stainless is a good call, I have a stainless from ebay, its been on 10 years or so without issue, they are pretty much a copy of the oem box but in stainless, slightly more noise but much lower tone so more rumble, not annoying to anyone, the fit can be a little tricky, be prepared to bend the brackets slightly but otherwise they are fine well mine was.
Really helpful. Thank you. I will order one of those from eBay especially as you’ve found it lasts so well. Thank you.
I have a Toyo that I got cheap from them as a second due to one of the brackets being wrong so I adapted the way I fitted it.
Good luck with your search.
James
talkingcars wrote: Hi and welcome to the forum
James
Thanks James for the welcome and advice.
I have ordered a stainless steel one made by Gravity. Hopefully that will do the trick.
Colin
David Aiketgate wrote: Let us know what it's like when you get it fitted. Pics are compulsory, lol!
I will do. Let’s hope it doesn’t turn into a scary movie of stubborn bolts and new brackets that don’t fit! I’ll post some pics and let you know if it sounds ok too.
