Engine compression test
Engine compression test was created by Prestissimo
Posted 3 years 5 months ago #195816
Hi All
Have the engine our on my 2003  TF 160. It's time to strip and paint the subframe and repair a split hose on the oil cooler.
I should have done a compression test before engine removal!
Anyone able to suggest how I might do this with the engine out of the car?
Replied by talkingcars on topic Engine compression test
Posted 3 years 5 months ago #195919
I think you can do a compression test just turning the engine over by hand.
Replied by Cobber on topic Engine compression test
Posted 3 years 5 months ago #195929
OK so the engine and transmission are out of the car but still together on the subframe.... yes?
Then remove all the spark plugs and connect a battery to the starter motor and earth it to the engine, apply + current to the small starter terminal on the starter soleniod whilst you do the compression test.
Make sure the whole subframe assembly is stable (can't fall arse over tit) and the gearbag is in neutral, whilst staying well clear of any moving parts (drive belts, pulleys etc.)
To do this I'd make up a couple of battery cables with eye terminals at the engine end and suitable battery terminals at the other and a push button starter switch wired from the + to the small starter terminal.
Oh..... do make sure you have oil in the engine and gear box, you don't have to worry about coolant as your not starting the engine.
Last Edit:3 years 5 months ago by Cobber
Last edit: 3 years 5 months ago by Cobber.
Time to create page: 0.516 seconds
