inlet Gasket Failure
Has anyone experienced IHG failure which allows coolant to get into the sump?
I'm investigating a problem with my TF.
Purchased as possible HGF.
Minor loss of coolant.
Steam from exhaust on start-up after being idle for a few days. Rectifies after reaching temperature.
No oil in coolant.
Can anyone confirm this as IGF?
Thanks in advance
JR
No oil in coolant.
Thanks in advance
JR
by JRPilot
Both of our F's have had inlet manifold gasket failure, which does result in a minor loss of coolant. The original type of inlet manifold gasket was known to go hard, resulting in coolant leak. Coolant was found leaking down the side of the engine block, not easy to see but I found adding coolant dye helped.
A bit of steam from the exhaust on startup is completely normal for any car, as long as it disappears after a couple minutes.
[size=10pt]Mark[/size]
95 MGF
by mowog73
Thanks Mark.
My problem is that it appears as if water is getting in the sump. (White moisture on dipstick).
So my query was can water get into the engine inlets and subsequently into the oil when left standing. (little used car).
I suppose I'll just replace the gasket and take it from there
by JRPilot
It would be very unusual to get water in the sump from an inlet gasket failure. Usually down to the head gasket or worse...
Incidentally, changing to an alloy inlet manifold is the permanent cure to a bendy plastic one leaking.
Thanks David, it already has the alloy manifold. So next is to pressurise the coolant. See if leakage can be seen - or not!
by JRPilot
Well I'm taking the bull by the horns - taking the head off. So we'll see
by JRPilot
I can't think of anyway that coolant could leak from the gasket through to the sump unless it is going in to the valve chamber, entering the combustion chamber and leaking past a cylinder.
It isn't uncommon to get a little bit of mayo on the dipstick if the car isn't used much.
Have you checked the underneath of the oil cap that is above the engine, not the one accessible from the boot by the dipstick.
by talkingcars
Thanks Talkingcars.
I’m changing the HG etc.
The thing which confirmed this action was a test to idle till reaching normal temperature. Once up the engine would function normally except that with some regularity there would be a puff of white from the exhaust.
By the way - the Mayo had been checked — just a little in the cap but some could be seen on the surface of the rocker gasket. I had expected an HGF would produce more - hence investigating elsewhere.
Thanks again. JR
Thanks again. JR
by JRPilot
Time to create page: 0.611 seconds
