strange miss-firing
strange miss-firing was created by pandrew3
Posted 3 years 5 months ago #196035
back story: on day one I had an engine miss for 20 seconds then cleared, day 2, miss fired for about 10 minutes then cleared, day 3 miss didn't clear.  replaced coil paks, plugs and leads. No miss for about 5klm then back to missing. Pscan said #2 solenoid in the Hydraulic cam control failed, replaced the unit, car ran for 6klm then back to miss. Did the plug lead off test, #1 cylinder problem.  Compression test gives #1 at 20lbs and all others at 160lbs.  Put a camera down the spark plug hole and 1 valve just hanging open. Replaced cam sensor, car drives OK for 5 klm then back to miss.  Compression test now has all cylinders at 175lbs EXCEPT #3, number1 is OK!  Cam angle sensor replaced, car drives until miss comes back 4klm into drive.  Now #2 has no compression  and ALL other cylinders at 175lbs! I am now waiting for an O2 sensor and mail to Australia is a bit slow at the moment.  Any suggestions?  And to keep with the level of frustration, the laptop with the Pscan diagnostic software has died too.
Replied by pandrew3 on topic strange miss-firing
Posted 3 years 5 months ago #196036
The car is an MGTF 160, year 2002 with 72000klm. I missed that bit in the above story..
Replied by Cobber on topic strange miss-firing
Posted 3 years 5 months ago #196037
Where abouts in Oz are you?
Posted 3 years 5 months ago #196038
Cleveland area, (Thornlands) QLD
Replied by julianfoulger on topic strange miss-firing
Posted 3 years 5 months ago #196039
Have you checked the integrity of the cabling TO the coil packs?
Compression test results do not look right and may well be a red herring. I have no idea whether you are using the cheapo kit or the real McKoy. I assume that you took out the fuse to the fuel pump and did the test by turning over the starter. As you probably know, the meter reads the highest reading whilst the engine is turned over. As the spark plugs are situated well down in the head, just make sure no air leakage between the head and the meter.
Posted 3 years 5 months ago #196042
As I'm in Burwood Melbourne, it'd be difficult to help directly being @ 1800 km away!
Last Edit:3 years 5 months ago by Cobber
Last edit: 3 years 5 months ago by Cobber.
Posted 3 years 5 months ago #196044
Hi Julin, I have not checked the wire to the coil pals.  I didn't pull the fuse to the petrol pump on the 1st test but the fuel spray reminded me very quickly.  I use a professional compression tester that screws into the spark-plug hole.  and could see one valve just open on each test.  I did check timing to make sure that the motor was supposed to have no valve open.Spooky.
Replied by talkingcars on topic strange miss-firing
Posted 3 years 5 months ago #196047
Sounds like several problems there.
How long have you owned the car?
James
Time to create page: 0.511 seconds
