TF emergency bonnet release
TF emergency bonnet release was created by rosey
Posted 3 years 5 months ago #196081
Hi
I'm thinking of fitting an emergency bonnet release on my TF the details of which have been posted some years ago. I think you can access the catch by removing the radiator cover- 7 x 10mm bolts and 5 x crosshead screws on top of the bumper. Would doing it this way mean that the bonnet catch needs adjusting when finished or is it just unbolt, do job and bolt up?
Cheers
Jon
by rosey
Replied by talkingcars on topic TF emergency bonnet release
Posted 3 years 5 months ago #196082
If you undo the bolts and screws you list you will release the slam panel.
If you fit it back exactly where it was it shouldn't need adjusting.
If you need to undo and redo the latch bolts don't over tighten the bolts as too tight and it won't work, IIRC they are 15 NM.
Replied by David Aiketgate on topic TF emergency bonnet release
Posted 3 years 5 months ago #196087
As a slight aside, I fitted an electric bonnet release as a primary system. I shortened the cable for the manual release and it's hidden in the cabin as the backup system.
It wasn't too difficult to fit the electric release, ( just an electric boot popper). The only modification was to replace the original catch spring with a slightly lighter one. The electric release is operated through a visible  but disguised switch and a second hidden switch.
I've had this fitted for a couple of years without issue.
Last Edit:3 years 5 months ago by David Aiketgate
Last edit: 3 years 5 months ago by David Aiketgate.
Replied by rosey on topic TF emergency bonnet release
Posted 3 years 5 months ago #196096
Thanks Talking Cars.
by rosey
Posted 3 years 5 months ago #196097
Thanks David, interesting mod!
by rosey
Time to create page: 0.502 seconds
