RAVE cd downloads
RAVE cd downloads was created by martin l
Posted 3 years 4 months ago #196221
How do yo down load the Rave CDs, I,ve tried to do it but all I end up with are empty files. I,m using windows 10 if that helps.
Replied by gloscs on topic RAVE cd downloads
Posted 3 years 4 months ago #196222
The zip file would appear to be currupt. Perhaps the uploader can re- upload?
by gloscs
Replied by Roverlike on topic RAVE cd downloads
Posted 3 years 4 months ago #196224
Which file you tried to download (A, B, C or D) and in which format (zip or ISO image)?
What you did after you downloaded it?
The following user(s) said Thank You: Cobber
Replied by martin l on topic RAVE cd downloads
Posted 3 years 4 months ago #196226
Not being sure which one I needed I have tried to download all  zip files, then after extracting  I had all the files but nothing on them (see attachment)
Posted 3 years 4 months ago #196227
Can you define what you mean nothing on them?
If you mean that you cannot open pdf file, then you are correct, you cannot open single pdf file because it is encrypted. Only thing you can do is to start program tdata (under Windows operating system) and find information you need. Zip files you downloaded do not work other ways.
On the other hand if youmare,using Windows 10 build number 2004 or later you might have problems with running Adobe Acrobat from tdata.exe file. In that case you can try following:
1) Copy the CD contents into a folder on your harddrive or USB stick.
2) Locate and open the 'Acrobat4' folder.
3) Open the 'Resource' folder.
4) Delete the folders 'CMap' and 'Font' or rename them
Rave will now open and run, you may get a warning of missing fonts but it doesn't seem to cause any other issues.
Last Edit:3 years 4 months ago by Roverlike
Last edit: 3 years 4 months ago by Roverlike.
Posted 3 years 4 months ago #196228
Thank you for the help
I will give it ago
Posted 3 years 4 months ago #196229
Thanks again its now working
Posted 3 years 4 months ago #196231
Glad it is working now.
Time to create page: 0.543 seconds
