Engine mount bolt
- TwistedPuppet
- Journeyman MGer
Hi,
Benn doing the cambelt and was all going fine until I went to remove the two top engine mounting bolts.
I have removed one, other is siezed.
Bolts have been sprayed with Plusgas every day for a week. I have tried 450nm impact gun and a long breaker bar and pipe. Using a breaker bar I sheared off a 1/2 long extension bar, left tip in the socket!!!!!!!
Bolt head is still ok.
The bolt I have gotten out was covered in white corrosion. NO anti-seize. Before I got the car the last cambelt change was by a garage four years ago. They clearly don't like using it, must be a **** garage.
Last thing I can think of is heat via a blowtorch, would that be ok on this as the mount is aluminum I think?
Cheers,
Iain.
Cheers,
Iain.
Heat is fine, you will have a hard job melting the aluminium with a blow torch!
Also use a quality 6 point socket, not cheap 12 point. Much less chance of rounding the bolt off.
Doesnt sound like quality extension bar if it sheared though!
Make sure thoroughly clean around bolt.
They are difficult to get at and remove.
by G0RSQ
- SundanceUK
- TwistedPuppet
- Journeyman MGer
Hi,
Thanks for replies
Halfords gave me a new 1/2 inch extension without asking any questions.
Tools are not the best but not crap either. Got a 200 piece Halfords Advanced set when on sale.
It has the newer style impact ball joints in it. These sets are better than they used to be, all six fltas and metric and wobble bar extensions etc.
I have proper impact sockets as well.
Tried heating with a blow torch about six times now, no luck. I am hoping that repeated heat cycles will crack the corrosion eventually. If not the it is either drill out or remove the mount from the engine and arm support thing it seemsd.
Drilling out looks to be tricky because of angle of bolt and room. Big bolt as well.
I Just know if i try to remove the mount the other bolts will be siezed.
I'll keep at it
There is a garage down the road I might ask them, pay them for an hours labour to have a go.
P.S.
Swearing at the bolt does not work no matter how profane.
Iain.
Thanks for replies
I'll keep at it
P.S.
Iain.
- BruceTF135
450Nm Impact gun might not be enough, TBF. I have a cheap 350nM mains-powered impact wrench I bought from Lidl and it wouldn't undo the wheel nuts on my van. They undid fairly easily with the vehicle's emergency wheel wrench. I'm sure that a garage workshop will have a more powerful wrench at its disposal.
by BruceTF135
I disagree, to work on cars, one has to have a fulsome arsenal of obscenities, profanities, vulgarities, oaths, curses, threats and insults.
There have been scientific studies that have indicated, there are many benefits to a well chosen and timed swear.
These include:
- Peak Strength. An increase in peak strength (useful when you're swinging on that breaker bar)
- Pain relief. Swearing activates the so-called ‘fight or flight’ response, leading to a surge of adrenaline and a subsequent pain relieving effect on our immune system. (handy when that bloody breaker bar slips and you skin your knuckles)
- Non-violent Outlet. Swearing enables us to get back at bad people or situations without having to resort to traditional violence, or something more menacing or harmful. It can be considered an act of sublimation, whereby we channel our anger by swearing instead, in what is seen as a ‘healthier’ outlet to help release our negative emotions. (Though the psychological benefits of taking to a stubborn and uncooperative inanimate object with a 2kg mash hammer are not to be under estimated!)
- Harmless & Humorous Coping Mechanism. This coping mechanism, although far from a great one, can serve to increase our sense of self esteem, when it seems deflated, threatened or attacked. This in turn helps to build our inner resilience, and confidence in the midst of perceived tension and stress. (your inner self believes it will overcome that bastard bolt)
- Assertion of Power/Control. Swearing can give us a greater sense of power and control over a bad or negative situation. By swearing we show that we have the power to control a situation, and not have the situation control us. This usually happens, ironically, when things are spinning out of control for us, and when things are not necessarily going our way. A person need not be the actual trigger for swearing to occur, but a particular unpleasant situation can be the trigger. (You are the master of the machine, it is not the master of you. and it better not not forget it......see previous reference to 2kg mash hammer)
