Switched Live from Fusebox
Switched Live from Fusebox was created by Fisher
Posted 3 years 3 months ago #196607
Hi All - Wiish to connect my new fuse board to a swiched live (only live with the ignition on) from the drivers understeering fuse panel. Can anyone recomment which fuse to use. I will be using a fuse piggy-back connector.
Do no want to use ciggye lighter (its permenant live) or Radio. Have attaches a photo of my fuse board.
Many thanks
Last Edit:3 years 3 months ago by Fisher
Last edit: 3 years 3 months ago by David Aiketgate. Reason: pic added
Replied by julianfoulger on topic Switched Live from Fusebox
Posted 3 years 3 months ago #196609
I do not have a TF but on the F are three spare connectors numbered 3, 4 and 5
No 3 - Ignition switched +
No 4 - Left sidelight feed +/ Front fog lights
No 5 – Perm live +/Front fog lights
I cannot see these three connectors in your photo so you may not have them.
Replied by BruceTF135 on topic Switched Live from Fusebox
Posted 3 years 3 months ago #196689
There should be a schematic on the flap that folds down to reveal this fusebox that shows what all of the fuses are for. Also, in the downloads section, I believe there is a .pdf of the TF wiring diagrams and maybe the owner's manual. For my DRLs, I used the fuse reserved for the AC, which my car does not have.
Time to create page: 0.482 seconds
