MG TF brakes binding on - all four corners?
- RickyGlasgow
- Apprentice MGer
MG TF brakes binding on - all four corners? was created by RickyGlasgow
Posted 3 years 3 months ago #196612A couple of weeks ago I noticed the car (MGTF160 MY2004) was 'dragging' on a short local trip of 2-3miles. Had to stop, found the back discs were red hot. Waited 30-40min, they had free'd up and I limped it home at low speed. Figured I'd throw everything at it since it was on my to-do list anyway - replaced rear discs, shims, pads, calipers, and flexi hoses. Bled it thoroughly, road-tested, and all seemed good. Couple of days later travelled down to Yorkshire (from Glasgow) and back - shout out to Jon and Claire at Rough Luck Racing, new cambelt! - with zero issues. Now the weird bit - couple of days after that trouble-free 500mile round trip, I got the same dragging feeling on a short trip (3-4miles). I jacked up the front and found both fronts were hard to turn by hand and discs were hot. Unfortunately I couldn't verify if the rears were locked up as well, as my trolley jack failed on me, but the rear discs were certainly also hot. Had to park up, get home on the bus, and go retrieve it that evening. Brakes had free'd up by that point but still baby'd it home. Handbrake is not holding on.
Now, I already have new discs, pads, and braided flexi hoses on hand for the fronts (as it was on my to-do list, again), but would you have any other thoughts on this? All four corners - if that is truly the case - makes my mind go to the master cylinder, but without further troubleshooting I don't want to jump to conclusions. The pedal seems to return to it's normal position and doesn't feel harder/softer than normal. I have noticed quite a bit of 'flex' on the master/servo assembly - it moves noticeably as the brake pedal is pressed/released so I have also ordered up the servo bracket stiffener kit from MGMania (link below).
First thing is to replace the front flexis (rears already done) which have been known to collapse internally and hold pressure on the caliper side which slowly releases back to the rest of the system, and fit the additional bracket to the servo. Then, if/when it happens again I plan to verify all four corners are stuck, and then loosen the bleed valves to check if the issue is fluid pressure being maintained (points to system fault, MC etc.) or, alternatively, if the calipers are not still pressurised (points to fault with individual caliper). Any experiences/insight from the community that might help me root cause this intermittent problem?
Replied by Cobber on topic MG TF brakes binding on - all four corners?
Posted 3 years 3 months ago #196613"Keep calm, relax, focus on the problem & PULL THE BLOODY TRIGGER"
- RickyGlasgow
- Apprentice MGer
Replied by RickyGlasgow on topic MG TF brakes binding on - all four corners?
Posted 3 years 3 months ago #196614Please Log in or Create an account to join the conversation.
Posted 3 years 3 months ago #196617"Keep calm, relax, focus on the problem & PULL THE BLOODY TRIGGER"
Replied by David Aiketgate on topic MG TF brakes binding on - all four corners?
Posted 3 years 3 months ago #196622Another more rare effect is the shaft that connects the master cylinder to the servo can get jammed by heat so that the servo is permanently on.. I believe it is possible to to adjust the length of the shaft. Giggity!
- RickyGlasgow
- Apprentice MGer
Posted 3 years 3 months ago #196629[Any theories why I could get 500miles no problem after giving it the 'kitchen sink' approach on the rears, and then it craps out on a 3mile trip? Or do we just file it under 'one of those things'?]
I'll report back here when done - it'll be 2-3weeks before I get back to it (right knee op today to try and save my running career!). Thanks again - I'm fairly new to the TF - always wanted an F/TF and the time was finally right a few months ago. It's great figuring things out, improving the car as you go along, and these forums are a fantastic resource.
Replied by G0RSQ on topic MG TF brakes binding on - all four corners?
Posted 3 years 3 months ago #196634When the brake peddle is released the piston in the master cylinder should move to a position that opens up the brake lines to the fluid resevoir.I would eliminate the master cylinder first. There is a valve within it that is supposed to allow brake fluid back into the master after you release the brake pedal. That could have failed.
This is to both release excess pressure in the fluid due to brake heat, and to allow fluid to replenish the slave cylinders as the pads wear, and pistons move further out.
Fault does sound very much like this is not happening, either through a faulty return spring in the master cylinder, sticking brake peddle not fully returning, or a damaged seal in the master cylinder blocking the fluid path from resevoir to the brake lines.
- RickyGlasgow
- Apprentice MGer
Posted 3 years 3 months ago #196772I also fitted the servo brace bracket kit from MG-Mania - that's a seperate tale for which I'll start a new post. In brief, the bracket as supplied does not fit correctly and had to be adjusted to make it work.
- RickyGlasgow
- Apprentice MGer
Posted 3 years 2 months ago #197011Related subject - I don't see any "How To's" on the ABS in general - best way to purge it, bleed it, program it ............
Replied by talkingcars on topic MG TF brakes binding on - all four corners?
Posted 3 years 2 months ago #197014(there is a pscan sub forum within the T Bar forum).
