Radio
Hi,
I’ve only had my MG TF 6 months and it cam with a rubbish radio, can I please have a few suggestions for a replacement.
How easy is to fit a DAB aerial? And is it worth it?
by Bobb
I have a sony Dab radio It's great. This is the latest version
https://www.amazon.co.uk/Sony-MEXN7300KIT-EUR/dp/B07N1ZHQ2S/ref=sr_1_4?dchild=1&keywords=sony+car+dab+radio&qid=1630008732&sr=8-4
Last Edit:3 years 2 months ago
by Bob
Last edit: 3 years 2 months ago by Bob.
I also have a Sony DAB which I find is very good and if you get one like mine you don't need a DAB aerial as it has a built in signal amp, all I had to do was a couple of connections on the back of the radio before fitting. I originally thought my aerial was NFG and was prepared to change it but it works fine with the Sony so I kept it.
by deepfat
Some years ago I fitted a Kenwood DAB+ radio and a 3db high-gain antenna on a ball mount opposite the existing FM antenna.
I get excellent DAB reception way out of the normal range from the transmitters.
I have a windscreen mounted dab aerial. Seems to give good reception.
https://www.amazon.co.uk/DriveSmart-Replacement-Antenna-Digtial-Windscreen/dp/B07HQSFV6S/ref=pd_day0fbt_img_2/261-1917703-0352310?pd_rd_w=OcKuV&pf_rd_p=93e1d4b1-bb8c-45f0-baaf-a13934852b31&pf_rd_r=DD5JNSWTPJ53RX6JMFPB&pd_rd_r=cac070bf-e2b0-4257-a7da-d29e1fed49db&pd_rd_wg=vEaPN&pd_rd_i=B07HQSFV6S&psc=1
by David Aiketgate
Last edit: 3 years 2 months ago by David Aiketgate.
- julianfoulger
I have a Pioneer AVH - Dab, FM, CD, Satnav, mobile inbuilt. I bought from Germany an FM aerial converter to DAB so I can use the same MG FM radio for the DAB. DAB and FM work great. GPS receiver under the instrument cowl also works well.
I did not want crap cluttering up the cabin (DAB receiver, GPS receiver, mobile receiver) and to keep it as close to stock as possible. I have kept the original MG Philips radio incase I want to take it back to real stock.
