TF handbrake cable change
TF handbrake cable change was created by pete l
Posted 3 years 2 months ago #196977
Hi all.
Is there a how to on changing à handbrake cable on a TF ?
Mine is full of rusty water and is sticking, it's worn the pads down and turned the disk blue!!!
Thanks. Pete.
by pete l
Replied by Raccoon on topic TF handbrake cable change
Posted 3 years 2 months ago #196984
Last Edit:3 years 2 months ago by Raccoon
Last edit: 3 years 2 months ago by Raccoon.
Replied by pete l on topic TF handbrake cable change
Posted 3 years 2 months ago #196990
Thanks for that. What about with the subframe exhaust etc still on the car. Seems there might be a probleme getting a plate off between the subframe and body.
Any views?
Pete.
by pete l
Replied by David Aiketgate on topic TF handbrake cable change
Posted 3 years 2 months ago #196991
I understand that the closing plate is an absolute pig to get off with the subframe in place. It is just possible but the assistance of a 5 year-old gynaecologist may help...
Posted 3 years 1 month ago #197112
Coming back to this. My new cable arrived and looking at it, I’m wondering if that nasty closing plate needs to be removed. Can I not just pull the cable through the hole in the closing plate then feed the new one through ?
by pete l
Replied by talkingcars on topic TF handbrake cable change
Posted 3 years 1 month ago #197119
You can get to the bolts for the plate from underneath, easy if you have a 2 post lift.
IIRC The plate needs to come away as the shoulder on the cable slips side ways on to the plate.
Time to create page: 0.507 seconds
