MGTF Damper Units
MGTF Damper Units was created by g4wam
Posted 3 years 1 month ago #197088
Hi all,
Does anyone know if the lower bushes on MGTF damper units can be replaced?
thanks
Mike
by g4wam
Replied by deepfat on topic MGTF Damper Units
Posted 3 years 1 month ago #197092
Don't really know but will this help
https://www.mg-rover.org/threads/mg-tf-front-shocks-bottom-bush.858945/
by deepfat
Replied by trevtherevs on topic MGTF Damper Units
Posted 3 years 1 month ago #197113
I had one of mine replaced recently so Yes they can be.:woohoo:
Replied by g4wam on topic MGTF Damper Units
Posted 3 years 1 month ago #197114
thanks deepfat-unfortunately the info is relative to the bottom bush bolt
Mike
by g4wam
Posted 3 years 1 month ago #197115
hi trevtherevs
the next question is do you have a part number for said bush
Mike
by g4wam
Replied by talkingcars on topic MGTF Damper Units
Posted 3 years 1 month ago #197117
Mike
Isn't that what you asked for?
Posted 3 years 1 month ago #197124
Hi-
no I specified bottom bush .
It transpires that they are available as a sperate item from MGFNTFBITZ.
Not cheap but a fraction of the cost of a new damper unit ,especially since the springs and dampers are usually ok .
The upper bushes and lower bush unit are the culprits and that makes it a worth while job to refurb an existing front or rear shock assy especially if you have the soft shockers fitted to your 2005 MGTF already and it failed MOT on bushes.
What I need to do now is work out if I can remove and refit the lower bush using home DIY methods
Mike
by g4wam
Replied by G0RSQ on topic MGTF Damper Units
Posted 3 years 1 month ago #197131
How confident are you the dampers are good? If they are how much longer will they last?
Cheaper is not always the best solution.
by G0RSQ
Posted 3 years 1 month ago #197142
Bob,
I am having a terrible time getting my rebuilt shocker units back into the turret-the centre line of the lower bush is too low to mate with the upper arm recess and I cant compress the suspension enough to line everything up.
The rebuilt shockers are assembled correctly and have the same length as the old units.
It appears the the rubber isolator at the top which goes into the roof of the turret is stopping the shocker from lining up at the bottom mating place.
Without the rubber isolator the match is prefect -obviously cant leave this out so how to compress everything
any ideas
Mike
by g4wam
Replied by Bob on topic MGTF Damper Units
Posted 3 years 1 month ago #197147
Sorry Mike I didn't have that problem when I did mine. perhaps the damper has opened a bit?
Can you compress the unit slightly with a jack when you install it?
by Bob
Time to create page: 2.499 seconds
