Sticking throttle
As an extra benefit, you should get a crisper throttle response!
It's almost unheard of for an alloy throttle body to stick.
- sworkscooper
John.
I've also developed a stutter when decelerating when the engine is warm which I don't think is related and is possibly a dirty IACV ( the ticking from what I understand is the IACV when I turn the ignition on is going on longer than usual I think) I'm going to clean that too.
So I installed a new cable as I had the same issue as you do with the engine idling erratically. Made no difference.
Turned out is was the peddle sticking.
