Anti Roll Bar Removal behind seats
I recently bought an MGF that has had a new hood fitted including a new glass back screen. I need to remove the Anti Roll Bar before I put the hood down as there isn't enough room for the rear screen with that in place.
The person who fitted the hood, said that it was easy to do and needs to be removed before putting roof down otherwise glass will break, but I just can't see how to do it?!
Any advise would be super helpful. Thank you in advance.
Cathy
- sworkscooper
Replied by sworkscooper on topic Anti Roll Bar Removal behind seats
Posted 3 years 4 weeks ago #197401I have a TF and as it doesn't have roll hoops I'm afraid I can't advise you but, there are loads of helpful and knowledgeable folk on the forum who will be along soon to help you .
John .
Aww, thank you! I'm glad to have found this group! :woohoo: :woohoo:
Replied by talkingcars on topic Anti Roll Bar Removal behind seats
Posted 3 years 4 weeks ago #197407I can't see the roof folding down with them in there.
I suspect you will have to remove the T bar (the bit with the speakers) to access the bolts to remove those hoops.
Have a look in the how to guides on T bar removal.
James
Just to clarify, an anti roll bar is actually part of the suspension beneath the car, usually one on the front and one on the back. What you have here are roll hoops, more for decoration than practicality.
Mike
- sworkscooper
Posted 3 years 4 weeks ago #197412Please Log in or Create an account to join the conversation.
- julianfoulger
Replied by julianfoulger on topic Anti Roll Bar Removal behind seats
Posted 3 years 3 weeks ago #197415http://mgf.ultimatemg.com/group2/DIY/hoops/index.htm
To get to the engine, the hoops will need to be dismantled.
If your screen was plastic, you could get the roof down without dismantling. However, have you tried unzipping the glass screen first and tucking it down before lowering the roof?
Replied by David Aiketgate on topic Anti Roll Bar Removal behind seats
Posted 3 years 3 weeks ago #197418David
- sworkscooper
Posted 3 years 3 weeks ago #197419There is a 'How to ' section on the forum which is very helpful but it depends very much on the individual when it comes to tackling jobs of this sort . As someone has suggested , the rear screen should have a zip section that will allow that part of the screen to fold / flop down into the space behind but I'm not sure this will help . The T bar ( the section behind the seat tops ) looks as if it needs removing to gain access to the roll hoop fixing and although not difficult to do for those of us familiar with how it fastens , I think you would have to very plucky to have a go yourself . Without giving your address , where in the UK are you based ? There might be someone on this forum who may offer to help you out .
John
- SundanceUK
Replied by SundanceUK on topic Anti Roll Bar Removal behind seats
Posted 3 years 3 weeks ago #197427I have the Mk.2 type fitted and think they look great.
Sundance
This how to should be what you want http://mgf.ultimatemg.com/group2/DIY/hoops/index.htm
You'll probably need a new engine cover carpet too as the old one will have been cut up to fit the hoops.
- bryan young
Replied by bryan young on topic Anti Roll Bar Removal behind seats
Posted 3 years 3 weeks ago #197450With the Hoops out of the way the glass rear window will fold and sit on the parcel shelf behind the T Bar allowing the roof to open properly . Good luck
