Timing belt change
The manual tensioner and 143 tooth/23mm wide belt is for 160 vvc engines.
The manual tensioner was also used on all engines up to some time in 1999.
- bryan young
That's what I would have expected, Bryan. (Good to see you back.)David, my 1996 MGF 120ps mpi engine has a manual tensioner despite being advised that it had an auto one and a 26mm belt .
All pre 99 cars had the manual tensioner.:yesnod:
The 135 will definitely have the auto tensioner and 26mm belt.Now that's what worries me. I see both types advertised as fitting the TF 135. I am thinking the only way to know is to get the car up, covers off the engine and look. Didn't want to do that because it's my only transport at the moment and I can't walk far because of arthritis. Ah well it is what it is I suppose.
- julianfoulger
My advice is to do the proper research. Get the engine number (I am not sure the Vin number is good enough) and check with Rimmers for the correct belt. The other option which I would be tempted to do is to take off the cam belt cover et al and check with your own eyes if auto or manual (easy to see) and measuring tape to ascertain whether a 23mm or 26mm belt.
- sworkscooper
John .
- bryan young
and one of the mobile mechanics advised me that one customers engine was a 1.6 engine instead of a 1.8, build date was years before the 1.6 engined MGF
- bryan young
I now have a copy of the MGF& TF database from Adrian Clifford which is far better than factory records and is correct and has the correct number of cars built, I did a lot of work with him in obtaining the Body numbers from owners, these were applied to the body by Mayflower/Stadco (the manufacturer) but were never recorded by MG rover or allocated to VIN's, these numbers are in the boot from VIN 4500, before this they were on a plate fixed to the floor under the passenger seat ( Seat and carpet needs to come out to see this) SO I can tell any owner the history of their car from the last six digits of the VIN - I have found this searching very interesting and have discovered some interesting cars.
I found a F/TF named 'Team Spirit' which was a TF built as an F ( with hydragas suspension) this car was rescued by a powertrain engineer from the crusher and he raced it with MGR approval as TEAM SPIRIT until MGR went bust, he bought it from the receivers. I was instrumental in getting this car as a display car at MGF20 at Gaydon.
I tried to get Adrian Clifford ( former registrar at the MGF REGISTER) to join the 'T' Bar forum, but he refused due to a substantial falling out with Jan Austin-Taylor!!!!
I will continue with my interference
Kind regards
Bryan
.....I tried to get Adrian Clifford ( former registrar at the MGF REGISTER) to join the 'T' Bar forum, but he refused due to a substantial falling out with Jan Austin-Taylor!!!!....
But she was banished from this parish many years ago, Adrian is more than welcome to join, please.
