Brake Lights possessed
- trevtherevs
- Apprentice MGer
I have been having a few problems since I put the front and rear subframes back in my mgtf. I currently have no reverse light which I intend to check the switch on the gearbox this week. However, as I brought the car out of the garage as I walked back to close the door down the rear brake lights flashed on and off then on for much longer, then off. I sat in and pressed the pedal a couple of times and could see the lights responding to the pedal movement. So walking to the rear again the brake lights again came on stayed on then off. Now, where should I start to look, or is my car possessed and some of the names I've called over the last week its taken exception to.
by trevtherevs
- sworkscooper
Hi . I think the general area of concern with anything like this is the boot hinge loom , where over time the wiring loom becomes brittle and fractures occur and rub together causing a multitude of problems . Investigate behind the conduit that covers the loom .
John
John
by sworkscooper
The following user(s) said Thank You: trevtherevs
While your at it, slide into the drivers foot well and unclip the brake switch which is half a turn. Pull the plunger right out and replace back in the bracket, the switch is cheap and nasty, i end up doing mine around twice a year, they can cause all sorts of issues.
by SteveFMk1
The following user(s) said Thank You: sworkscooper, trevtherevs
Time to create page: 0.543 seconds
