Wheel centre caps
My Trophy Blue TF has repro badges on the front and back that are Blue lettering on a silver background, however the wheel centre caps are Brown on Silver. I have been searching on line for caps to match the body badges ie Blue lettering on Silver.
I have tried MGOC spares, Rimmers, Brown & Gammons, MGFnTF, MGmania, eBay and google, anyone know who else to try?
by deepfat
I tried them David the problem is it is are virtually impossible to to get them in exact alignment to cover the existing logo resulting in a double vision effect, they are also flat and the cap is convex causing creases and if you stretch them they don't line up again. There is also the problem that there is no background to them so if by some miracle you fit them exactly you still have the cream background grinning at you, if anybody has had success with these stickers please share.
I have a spare cap and removed the insert (very tedious) only to discover the plastic body underneath is also convex!!
Currently I'm thinking, spray the existing caps silver to cover the logo then try to fit the stickers or get some generic plain caps (flat) then spray and fit the stickers.
by deepfat
- BruceTF135
by Raccoon
Thank you gentlemen but this is not as easy as it appears:
Bruce I've trawled ebay but have yet to find one the right size to fit a TF wheel opening, measuring my spare I want 54mm (55?) dia on the outside face and the sleeve that fits into the wheel is 44.6mm which I presume means 45mm and I can't find one as yet.
Bertie same prob I've seen them but they are 80mm to trim them to 50mm is I think a bit of an ask
by deepfat
- BruceTF135
They do 57mm as well: link to 57mm badge
by Raccoon
Rob thanks for that, after much searching I think I've found flat generic caps that will fit but wont be sure until they come. The caps are I believe 55mm which makes your decals a runner, time and the postman will tell.
by deepfat
Time to create page: 0.681 seconds
