eziblleed brake bleeding kits
does anyone if it is possible to get an ezibleed brake fluid reservoir cap that fits an MGF/TF ?
They only seem to supply a top that feeds the clutch master
thanks
Mike
thanks
Mike
by g4wam
They supply a universal adaptor but it costs almost as much as an eezibleed! I made my own using aluminium plate and M6 studding it works fine if you keep the pressure low so 5 PSI is plenty.
Last Edit:2 years 8 months ago
by Gavin207
Last edit: 2 years 8 months ago by Gavin207.
I decided to continue using by vacuum bleeder and if I can get a brake master cylinder top then try to modify one for an eezibleeder.
thanks
thanks
by g4wam
Sometimes the old ways are still the best.
Until someone makes a proper master cylinder cap this kit is hard to beat for a one person fluid change/brake bleed.
by kernow
Time to create page: 0.519 seconds
