Disassembling door handle
Disassembling door handle was created by deepfat
Posted 2 years 6 months ago #198973
I couldn't find a drivers door handle in trophy blue so now have to spray one up to match and need to remove the lifter handle from the body to do this properly. The handle is attached with 2 pins, can I tap these out either way or do they only come in/out one way?
Any other tips on this job welcome, thanks.
by deepfat
Replied by Airportable on topic Disassembling door handle
Posted 2 years 6 months ago #198976
I made a couple of tools & pressed them out as bashing them with a pin punch seemed to invite catastrophe. I’m no great lover of scroll pins & so I did a bit of engineering, replacing them with modified stainless cap head screws (m4?), much better job & if I need to revisit them it’ll straight forward. As I remember if you do press them out with a vice you’ll only be able to ease them out one way.
Replied by deepfat on topic Disassembling door handle
Posted 2 years 6 months ago #198993
Got the pins out relatively easily, I used a small drift you really want something with a flat end to it, if it's pointed it will have the effect of trying to open the roller pins out making them tighter. I also packed the space between the two arms of each pin to lesson the risk of snapping an arm off. The pins are uniform so can be knocked in/out any which way you prefer.
by deepfat
Time to create page: 0.472 seconds
