wires in engine compartment
wires in engine compartment was created by MikeW
Posted 2 years 6 months ago #199394
Bonjour, almost completed my engine change in my 1998 MGf. Thought I had tagged everything but!Seeputo showing 2 connectors on one line above the gearbox. They go off to a small box shown on second photo which seems to connect to several things including the loss of coolant wire. Can anyone tell me what they should connect to.
Last Edit:2 years 6 months ago by MikeW
Last edit: 2 years 6 months ago by David Aiketgate.
Replied by David Aiketgate on topic wires in engine compartment
Posted 2 years 6 months ago #199395
Do you mean the yellow/green wire? Thats standard domestic earth colours and it seems this is an aftermarket addition to your car, especially if you have a low coolant alarm. That is not standard on that age of car.
Sorry can't help much other than this.
Replied by Cobber on topic wires in engine compartment
Posted 2 years 6 months ago #199396
Yeah with those shitty blue crimp connections they are not original, they’re probably a part of a low coolant alarm and would intercept one of those other wires in the back ground.
If so they’d take the power feed to the low coolant alarm from the feed to the reverse light switch.
Last Edit:2 years 6 months ago by Cobber
Last edit: 2 years 6 months ago by Cobber.
Replied by MikeW on topic wires in engine compartment
Posted 2 years 6 months ago #199408
Thank you for your suggestions. I'm sure you are right about the coolant level. I installed a new coolant tank with a warning system some years ago. The corrugated tube in the second photo goes off to the tank but (my age is telling) I cannot remember the connections and can't find the fitting instructions.I attach a slightly better photo which shows the green yellow cable encased in a simple tubing which I am fairly sure I didn't install. I'tried to photo everything before dismantling which took place over a year ago have missed out this wiring. I don't know what the black box in the photo is for even thogh 4 wires connect into it.
by MikeW
Replied by BruceTF135 on topic wires in engine compartment
Posted 2 years 4 months ago #199685
Sorry, late picking this up as I have been off-grid for a while.
That looks like a very early version of one of my low coolant alarms. If you are still trying to fathom it out, drop me a private message.
Time to create page: 0.530 seconds
