Bonjour, Problem mostly solved. Bad connection of a multi plug buried behind the ECM.
The engine turns over quite sweetly except for a tap or click which follows the revs.
Also, the rev counter doesn't work. Coolant, temp, oil pressure all work. Haven't moved so don't know about the speedo.
I see something about an instrument pack. That sounds complicated.
