Replacement engine start up
Colant systel full and bled, oil and filter added.
It was suggested that I remove plugs and give short runs until oil pressure was obtained.
First problem was the key fobs . After battery changes and following the handbook re-registering, they work fine.
But the starter key does nothing. I have tried pressing the fob buttons after fitting the key. Everything else works, lights, doors.
What should I try and check first? I don't have a code reader. I feel quite useless.
Is the wire connected to the correct terminal?
One way to test if the starter motor is okay, and that the engine will turn over, is to bridge the bigger terminals of the solenoid with an old screwdriver, or use a jump lead. There will be sparks when you do this, but if the starter turns the engine, there is a fault either in the solenoid itself, or the wiring connections.
Hope you have good luck with this
Presumably it all worked prior to the engine change so why not now, have you checked the fuse? the wiring diagram will show what one because off the top of my head I don't know.
