CVT Gearbox speed sensor And speedo speed transducer earth point
I have a malfunction for the CVT speed sensor but changing the sensor hasn’t fixed the problem. Both the CVT speed sensor and the speedo speed transducer are supposed to earth to a point described as C0807 which is a 6 mm tinplate female located “rear of engine compartment”
I have attached an image of the site but I can’t find it on the car. —- 2003 TF
Can someone please give me a clearer idea of the exact location?
Thanking you in advance
Last Edit:2 years 1 month ago by Harry
Last edit: 2 years 1 month ago by David Aiketgate.
If it's just an earth, could you just use another convenient earthing point.
Replied by Harry on topic CVT Gearbox speed sensor And speedo speed transducer earth point
Posted 2 years 1 month ago #200138
Thanks for that and ultimately I may have to cut into the wiring near the sensors to create another earth but I can’t actually find this blessed wire that is supposed to be connected to the earth point shown.
I would hope a simple clean would be enough if I can find where it attaches
by Harry
Posted 2 years 1 month ago #200164
Found it!
It attaches to the engine block at the same point as the main earth strap that goes from the engine block to the body.
The body section attaches below the big fuse that is under where the TF reinforcing bars attach at the rear of the engine compartment. They are C0565 and C0807
by Harry
Time to create page: 0.479 seconds
