engine cover sound proofing
engine cover sound proofing was created by Shedifice
Posted 2 years 1 month ago #200283
Been in and accessed the engine again today! its always a pain removing and refitting the sound proofing and top plastic/fabric sheet.
The more I do it the more of a jigsaw I end with as bits fall off.
Question should the top plastic/fabric layer be attached to the sound proofing? Its half attached so I cant work out if it is supposed to be separate and has stuck together over time, or its supposed to be stuck but has separated over time.
L.
Replied by talkingcars on topic engine cover sound proofing
Posted 2 years 1 month ago #200288
I think it depends who put the car together.
I have had one where the carpet and sound proofing are separate items, one where they were glued together and one where the sound proofing was stuck to the actual metal engine covering.
Replied by julianfoulger on topic engine cover sound proofing
Posted 2 years 1 month ago #200292
I bought my car new in 1998. The top carpet and soundproofing were never glued to anything.
On the underside of the engine lid, the silver heat shield was/is glued.
Replied by Shedifice on topic engine cover sound proofing
Posted 2 years 1 month ago #200293
Julian, Were the carpet and sound proofing glued together?
Posted 2 years 4 weeks ago #200296
Nope. One just lies on the other.
Replied by BruceTF135 on topic engine cover sound proofing
Posted 2 years 4 weeks ago #200301
Not glued on mine and I've never seen one that was. n ~5.
Replied by Keymaster on topic engine cover sound proofing
Posted 2 years 3 weeks ago #200347
Replaced mine on both cars as they were crap and falling in bits. Used dense foam yoga mats cut to shape using a cardboard template.
Cheap, lighter and looks better.
Posted 2 years 1 week ago #200412
I thanks for response. It is amazing how heavy the sound proofing is.
Posted 2 years 1 week ago #200413
The engine lid gets very hot to the touch so I suspect that it is for heat insulation as well.
Posted 2 years 1 week ago #200414
agreed but still nearly gave me a hernia lifting it off!
  • Away
Replied by Cobber on topic engine cover sound proofing
Posted 2 years 1 week ago #200416
Yeah I think we can do better than the decomposing dead dog of an insulation mat, that MG decided to lump us with
Replied by minimax on topic engine cover sound proofing
Posted 2 years 1 week ago #200417
The bituminous layer is a good vibration damper and the heavy padding does a good job of cutting noise down. I don't think Yoga mats alone will give as much attenuation. I would try a bituminous pad on the engine cover as well. The mad scientist in me wonders if a few bits of plastic flexible conduit and a computer fan glued to the engine cover would act as an airscarf or rear window heater.
by minimax
Time to create page: 0.536 seconds
