engine cover sound proofing
The more I do it the more of a jigsaw I end with as bits fall off.
Question should the top plastic/fabric layer be attached to the sound proofing? Its half attached so I cant work out if it is supposed to be separate and has stuck together over time, or its supposed to be stuck but has separated over time.
L.
I have had one where the carpet and sound proofing are separate items, one where they were glued together and one where the sound proofing was stuck to the actual metal engine covering.
- julianfoulger
On the underside of the engine lid, the silver heat shield was/is glued.
- julianfoulger
- BruceTF135
Cheap, lighter and looks better.
- julianfoulger
