ABS pin outs ABS light on all the time
2002 TF been stood for about three years before I bought it.
Picked it up for peanuts as a non runner. Immobilizer out of sync and starter fuse corroded / blown.
I bought the car as my 17 year old sons first car.
Sorted most issues apart from the ABS light stays on.
Checked all sensors, and the connectors are dry , with 1.6 k ohms resistance on each, and 0.7 volts AC when I spin the wheels, so they all look ok
Took the connector of the pump, and all looks dry.
As I had a problem with fuse 19 (the starter circuit fuse) i thought fuse 20 (ABS) might be a bit iffy also, but put a lamp into the side of fuse and lit both sides.
So I would like to check everything from the ABS unit to make sure I have got a ground, live, and continuity all the way to the unit.
For this, I could do with the pin outs. Or any other advice. I have trawled the forums but no more answers without PSCAN
by Borgy
Replied by Borgy on topic ABS pin outs ABS light on all the time
Posted 1 year 11 months ago #200523
managed to find a MGF one. I assume its the same ?
by Borgy
- julianfoulger
Replied by julianfoulger on topic ABS pin outs ABS light on all the time
Posted 1 year 11 months ago #200533
mmmmmm.. don't bet on it. I have an MGF but I have full wiring diagrams for both F and TF and there are differences.
But the MGF wiring diagrams are a good start. Follow the colour codes from the ABS end.
Last Edit:1 year 11 months ago
by julianfoulger
Last edit: 1 year 11 months ago by julianfoulger.
- julianfoulger
Posted 1 year 11 months ago #200534
To be helpful I have attached a copy of the ABS wiring diagram for the TF.
Time to create page: 0.551 seconds
