Flat Battery - headlight issue
- mikegeemike
- Novice MGer
Hi folks, I wonder if anyone can shed a light on the issue I am currently having with my 2003 MGTF. After not using the car for three weeks when I went out the battery was flat and turned out that it wouldn't recharge. Luckily it was still under guarantee so I got a free replacement. The problem I'm having is when I reconnect the battery my dipped headlights come on and the only way I can turn them off is to disconnect the battery.
I had the same thing happen a couple of years ago and I solved it by replacing the red ECU (if that's what it is called) which is at the back of the fuseboard in the footwell. My question is surely this shouldn't need to be replaced every time the battery goes flat or should I be looking at something else.
Really baffled - by the way I'm not in any way a mechanic or an auto electrician but I do try and do things myself if possible.
Any help would be greatly appreciated.
Regards
Mike
Regards
Mike
by mikegeemike
MFU unit (red box behined fusebox) shoukd not have anything to do with headlights.
Only thing that can provide both dipped beams permanently on or permanently off is the steering column switch. If it is on, it might be stuck in connected position. In that case only replacement of the steering column switch will solve the problem.
by Roverlike
The following user(s) said Thank You: mikegeemike
- mikegeemike
- Novice MGer
Hi, thanks for the reply - I changed the steering stalk when this happened a couple of years ago and it made no difference it was only when I changed the EMU that the problem was rectified - I suppose it could have just been a fluke - I'm baffled by it to be honest. I could put the old stalk back on and see if that makes any difference. Would it be usual for two stalks to malfunction like this? It certainly is a puzzle.
Regards
Mike
Regards
Mike
by mikegeemike
Mike, it's an unusual problem. My first check would be the indicator/light control stalk, if this is serviceable then I would check the wiring harness back ton the main loom. If the stalk is disconnected and the fault is no longer there then its a stalk issue, if however there is still a fault then it would be a short in the harness between a permanent live feed and the headlights. This could still happen through the stalk though and a careful examination of the harness might be required. Check for any obvious signs of damage, either trapped wires or rodent activity! Hope that helps.
by TaffD
The following user(s) said Thank You: Airportable, mikegeemike
On my F I had wiring loom problems along the L/H inner mudguard/ wing/ fender/ whatever you call it where you are.
It was a short circuit in the loom, maybe that’s what killed your battery.
I cut the tape away from the loom, replaced the damaged sections of wire and retaped it…been fine since.
Could be Kangaroos kicking crap out of your cables Cobber causing catastrophic carnage.
Just a thought!
Just a thought!
by Airportable
- mikegeemike
- Novice MGer
Well the EMU arrived and has been duly fitted - hey presto problem solved. How bizarre is that.
by mikegeemike
Glad to hear you sorted it.
by TaffD
Time to create page: 0.660 seconds
