TGM10011
- sworkscooper
I would try Rimmer Bros .
by sworkscooper
Rimmers it appears no longer stock it, however Brown & Gammon in Baldock list it at £29 ish although it has a cryptic note adjacent reading “Request stock alert”.
by Airportable
EZL799 Spec oil should be available, try a BMW dealer, used in early Mini as its the same gearbox.
by Steve
Also try DMGRS discount MG Rover spares www.dmgrs.co.uk very helpful people.
by Steve
No longer available. Also, the one at B&G is for MINI not TF. It has different oil pick up and slightly different shape.
Bit naughty really as showing same part number. i had problems when I fitted that one and after a lot of searching decided to "modify" the strainer to look more like original, so far so good. I have ordered one from German web site, not holding my breath though.
by buzzbee
Thanks Steve, I know all at DMGRS he used to live a couple of doors up from us.
Buzzbee, I'll bear you in mind.
My other thoughts are change the oil fairly often.
Last Edit:1 year 10 months ago
by leekey
Last edit: 1 year 10 months ago by leekey.
I checked the catalogue of automaticchoice.com who have a filter for the BMW MINI box which is in the Rover MGF etc but clearly state that the OEM & non OEM units they have (the only ones available) do not fit the Rover MG F /TF boxes
by Harry
They do also have a BMW oil pan as a separate item. It might be that the pan is the only difference and the filter which sits in the pan with only an o ring seal to secure it is shaped to suit. If so will a MINI pan fit in an MGF and solve the problem?
by Harry
The following user(s) said Thank You: buzzbee
After having no luck with German supplier, time to look at other solutions. I modified my Mini filter to help with fluid circulation and seems to work. As metioned the BMW pan is samefitting as far as I can tell (gaskets are the same) so I am trying to locate a filter pan to try it out, fingers crossed.
by buzzbee
Time to create page: 0.512 seconds
