TGM10011
TGM10011 was created by leekey
Posted 1 year 10 months ago #201106
Hi, anybody know where I can get an gearbox oil filter for our MGF Stepspeed/Steptronic? The part number is TGM10011
by leekey
Replied by sworkscooper on topic TGM10011
Posted 1 year 10 months ago #201107
I would try Rimmer Bros .
Replied by Airportable on topic TGM10011
Posted 1 year 10 months ago #201108
Rimmers it appears no longer stock it, however Brown & Gammon in Baldock list it at £29 ish although it has a cryptic note adjacent reading “Request stock alert”.
Replied by leekey on topic TGM10011
Posted 1 year 10 months ago #201114
It appears it's no longer made. A bit of a surprise as the gearbox is used in other cars too.
by leekey
Replied by Steve on topic Re:TGM10011
Posted 1 year 10 months ago #201115
EZL799 Spec oil should be available, try a BMW dealer, used in early Mini as its the same gearbox.
by Steve
Posted 1 year 10 months ago #201116
Thanks Steve, it's not the oil I can get that but the filter. I'll try a BMW dealership or specialist as they must use something in their cars
by leekey
Posted 1 year 10 months ago #201117
Also try DMGRS discount MG Rover spares www.dmgrs.co.uk very helpful people.
by Steve
Replied by buzzbee on topic Re:TGM10011
Posted 1 year 10 months ago #201118
No longer available. Also, the one at B&G is for MINI not TF. It has different oil pick up and slightly different shape.
Bit naughty really as showing same part number. i had problems when I fitted that one and after a lot of searching decided to "modify" the strainer to look more like original, so far so good. I have ordered one from German web site, not holding my breath though.
by buzzbee
Posted 1 year 10 months ago #201119
Thanks Steve, I know all at DMGRS he used to live a couple of doors up from us.
Buzzbee, I'll bear you in mind.
My other thoughts are change the oil fairly often.
Last Edit:1 year 9 months ago by leekey
Last edit: 1 year 9 months ago by leekey.
Replied by Harry on topic TGM10011
Posted 1 year 9 months ago #201149
I checked the catalogue of automaticchoice.com who have a filter for the BMW MINI box which is in the Rover MGF etc but clearly state that the OEM & non OEM units they have (the only ones available) do not fit the Rover MG F /TF boxes
by Harry
Posted 1 year 9 months ago #201150
They do also have a BMW oil pan as a separate item. It might be that the pan is the only difference and the filter which sits in the pan with only an o ring seal to secure it is shaped to suit. If so will a MINI pan fit in an MGF and solve the problem?
by Harry
The following user(s) said Thank You: buzzbee
Replied by buzzbee on topic TGM10011
Posted 1 year 9 months ago #201158
After having no luck with German supplier, time to look at other solutions. I modified my Mini filter to help with fluid circulation and seems to work. As metioned the BMW pan is samefitting as far as I can tell (gaskets are the same) so I am trying to locate a filter pan to try it out, fingers crossed.
by buzzbee
Time to create page: 0.502 seconds
