Vehicle speed sensor
Having problems removing the speed sensor looking at it you can't get a spanner on the plastic nut having tried,have also undone the 8mm bolt holding the plate and can't move the plate at all,not sure how it comes out can someone help please.
Thanks in advance
Bob
Thanks in advance
Bob
by 1030bon
The sensor is in 3 parts.
The top part in photo is the gear mesh into the gearbox top held in by a bolt through the tab.
The middle part is the actual transducer and screws into the gear mesh assembly
The third , bottom, part is the electric plug. (This is normally the problem, corroded pins giving poor pulse signal to speedometer and EPAS.)
If you have undone the bolt spray , some penetrating fluid around the base , then pull and wiggle should work.
Cheers, and good luck, Mark
by markvrs
Hi Mark
Thank you for your reply really appreciate it, so to clarify the whole lot has to come out to change the sensor?
Many thanks
Bob
Many thanks
Bob
by 1030bon
No, all bits can be separated. You said you could not get a spanner on the sensor itself, so next move is to undo the bolt which you have already done and pull the whole thing out. Once the bolt is out it is only an O-ring and age holding it into the gearbox, then you can get a spanner onto the sensor.
If you can get a spanner / crows foot on the sensor then that will unscrew from the gear assembly.
by markvrs
The following user(s) said Thank You: Airportable, deepfat
Thank you Mark for all help and your time really appreciate it,so now I have a better understanding hopefully be able to tackle it.
Best regards
Bob
Best regards
Bob
by 1030bon
Thanks Mark a very clear and concise response, I now know that's its just a normal speedo drive with a transducer on it, now just need to find out WTF is a transducer, is it a "woke" term?
by deepfat
Hi deepfat
Quick google search reveals this.
A transducer is an electronic device that converts energy from one form to another. Common examples include microphones, loudspeakers, thermometers, position and pressure sensors, and antenna.
by 1030bon
Transduckter, used to be a duck but could be anything now.
by Airportable
This transducer is extremely cheap and easy way to covert a rotation into a pulse using Hall Effect. Basically a bit of metal wizzing past a magnet. Also used in electronic distributors to replace points system. Much cheaper than a 3 part speedo cable, and a wire is much easier to route.
by markvrs
A cross dressing duck perhaps? Or a cross dresser who does inappropriate things to ducks?Transduckter, used to be a duck but could be anything now.
Time to create page: 0.529 seconds
