TF 2002 IDLE AIR CONTROL VALVE
Hi Guys
I adjusted my throttle a few weeks ago as it had a lot of slack in it and was a nightmare to drive, since adjusting it I am experiencing cutting out when slowing down and at low revs, having gone through the posts it looks like my IDLE AIR CONTROL VALVE may be the issue or TPS? .
I have tried to reset the tps many times but no joy .. but with the throttle adjusted it drives a lot better until I slow down.
Where is best to buy one of these from? if anyone has a link be greatly appreciated, as I'm not sure what I'm buying
Many thanks, Paul
Many thanks, Paul
Last Edit:1 year 6 months ago
by MGPaulD
Last edit: 1 year 6 months ago by MGPaulD.
Replied by David Aiketgate on topic TF 2002 IDLE AIR CONTROL VALVE
Posted 1 year 6 months ago #201419
Stalling will most probably not be the IACV but an incorrectly set base idle.
This post clickky is relevant although it is addressing a rising and falling idle situation.
Follow that procedure, you may need to adjust the idle set screw on the throttle body initially to lift the idle sufficiently to get a stable idle without stalling.
by David Aiketgate
Last edit: 1 year 6 months ago by David Aiketgate.
Hi , thank you 😊 I will give this a try
by MGPaulD
Time to create page: 0.482 seconds
