Heater controls always on hot, knob broken
One of the last things to repair on the TF.
The heater is always on hot. (or cold now as I have moved the valve)
The valve was stuck a bit so I coerced it a little and adjusted the cable, but the knob still wasn't doing a great deal.
Took the knob off, but when i went to put it back on, the spline it is supposed to fit on pushed backwards and now is not sticking out. The knob itself has a split, so could be one of the reasons it wasn't moving the cable to operate the valve.
Do i need the console off to push this back through? Or is it likely to be buggered completely?
by Borgy
Replied by Airportable on topic Heater controls always on hot, knob broken
Posted 1 year 7 months ago #201657
If you go back about six weeks you will find a post called "Knobs" have a look at that, it might give you an idea.
by Airportable
Replied by TaffD on topic Heater controls always on hot, knob broken
Posted 1 year 7 months ago #201697
I had a similar problem and found the clips had come off my knobs! When I refitted them and tried to put my knobs back on one was not engaging, when I checked it had pushed the control shaft in, I had to strip down the controls again. The shaft runs through the controller and is held in place by a C clip. Replace the clip and all was good when rebuilt.
by TaffD
Time to create page: 0.469 seconds
