Fuel filling fusspot no more.
Fuel filling fusspot no more. was created by Airportable
Posted 9 months 2 weeks ago #205690
Every eighteen month I come on grumbling about the slow filling speed of the f.
I can pull up to a pump next to a Range Rover & commence to fill up, the Range Rover can pump three times the capacity as the MG & he’s full, paid, gone & has used a couple of gallon whilst I’m stood clacking away.
I’ve taken the restricted flap out of the filler neck, or to be more accurate two of the three welds had failed & it didn’t take much for the third to become detached.
Having found a new one at a price less than a crap used one I set about replacing the old one, not an exacting job unless the nylon nuts on the orange cover won’t shift & self destruct. I called on the scissors & having laid waste to it I discovered why I’d been struggling for all those years.
I’ll post some pictures & you can form your own opinions.
The final picture is what a new one is like & what it looks like now once I’d finished replacing the whole kit.
Last Edit:9 months 2 weeks ago by Airportable
Last edit: 9 months 2 weeks ago by Cobber.
Replied by bryan young on topic Fuel filling fusspot no more.
Posted 9 months 1 week ago #205731
I have a September 1996 build Mk1 MGF and I don't have a problem with fuel filling PROVIDED I put the fuel pump nozzle in in the right place ( quarter to) and don't pull the nozzle WIDE OPEN!! Stop filling at first click, (( been in daily use since 2012))
Replied by Airportable on topic Fuel filling fusspot no more.
Posted 9 months 1 week ago #205740
I look forward to the first fill up, there has to be a major improvement over what was supplied in 1998. You must agree that having a full bore as opposed to a wonky barrel should now exhibit, if not exactly a full bore filling, certainly a much improved squirt.
Posted 5 months 3 weeks ago #207052
I forgot to report back on this job, other things have drifted across the skyline since I offered this up for consideration.
The first fill up was indeed an event & the effort invested in the job was replayed by my driving up to the pump & filling up as if it were a “normal” car & no different from my daily driver.
If you have problems filling or need to adopt a strange posture whilst doing so do have a look at the rubber tube between the filler pipe & the tank, it may be kinked & chance would be a fine thing.
Time to create page: 0.521 seconds
