Re:opinion modification hydragas
I thought of cutting the Hydragas at the top where it contains nitrogen (I measured the capacity of the upper chamber at 0.5 liters), removing the membrane, and welding a 2-millimeter thick steel plate. Then, weld a 1/2 inch threaded connector and connect an external membrane pre-loaded nitrogen accumulator (0.5 liters) at 18 bar (the accumulators are tested up to 300 bar). Connect them together with a high-pressure hose, and hide the accumulators somewhere under the car.
What do you think? Am I talking a lot of nonsense or could it work and solve the issue? Comments or insults are welcome; I won't be offended :lol:
I attach the diagram
In theory I would think that your proposal would work, the problems that I see are 1st sealing the “cut” upper chamber, and 2nd would be finding space in a very cramped car to fit the new accumulators
Well done for thinking out of the box
The capacity of the remote vessel need not be great, but it’ll need structural integrity enough to take, not only the pressure but the fittings, (nitrogen fill & fluid transfer.
Go for it, it’s bit inspired & performance shock absorbers have used external reservoirs for years.
Blaze the trail.
Yes, the receiving vessel is relatively expensive especially when you have more work to do in cutting down the original spheres but when you have finished you will have a unique car.
Brilliant, lateral thinking in an up or down world.
.....which is approximately 17.59754 UK fluid ounces for the English-speaking audience..... [/attachment]
That will be the Americans, I was born in 1964 in England and only learnt metric measurement at school.
I look foward to updates on this project.
No not Quite, our American friends have different size ounces to the old UK fluid ounces
This is because in the UK a fluid ounce was determined by the volume of an ounce of water, where as in the US a a fluid ounce is determined by the volume of an ounce of wine.
I was born in 1961 and learned both systems at school including the American variations.
So to translate 17.59754 from UK ounces into US ounces in would be 16.907011 US ounces
Unfortunately this would probably be not worth the effort and cost involved to develop, but would ultimately be the best solution.
I will continue to give it thought and consideration though.
