Emissions Issues- Help
My 2004 TF has failed its MOT on emissions and I don't know how to get it to pass. I've tried a few things, and I'm rapidly getting to the point its just not worth spending more money on.
The emissions readings gave the following:
CO: 0.000%
HC: 1.4 ppm
Lambda: 1.345
I first tried an Italian tuneup and drive it hard for 30 mins and dropped it off straight into the MOT bay for retest. However, no luck.
The failure is on the Lambda. A scan with Pscan showed an electrical issue with the post cat oxygen sensor. This was replaced by a garage and the code is now gone, but the lambda hasn't come down.
The garage can't find "any obvious issues", and only recommend "sending the car to an ECU specialist".
Any thoughts?
I did some work quite recently where I amassed sensors from several types & makes of car, the characteristics are so close as to make you ask why such a price disparity.
I didn’t assess the dynamic characteristics of each by screwing them into the car, in turn & run it. Those tested gave similar results.
At the end of the day you’re looking for an MOT pass, the test is academic.
Is there anything I can look at in the live data from PScan to establish the health of the not-yet-replaced pre-cat sensor?
Change the other sensor & run the system stinking hot a couple of times & you’ll be in with a very good chance.
Unless the cat’ has croaked.
The pre cat lambda probe on the car is reading this ratio and the ECU is using that info to adjust the fuelling.
The post cat lambda probe is merely confirming to the ECU that the rest of the system is working, it plays no part in adjusting the fuelling.
Andy, have you got a pass now?
If you have no idea of what you're doing, talk a load of shit, with plenty of technobabble, gravitas, authority and a straight face, in the hope you bamboozle the audience.
Politicians TV presenters and senior management do it all the time!
