Stepspeed gearbox warning light- Some advice
- quicksilver
Stepspeed gearbox warning light- Some advice was created by quicksilver
Posted 14 years 9 months ago #9895Chris
Replied by gos on topic Stepspeed gearbox warning light- Some advice
Posted 14 years 9 months ago #9896Quicksilver;9895 wrote: At this time of year there are a rash of Stepspeed owners contacting their local garage because the gearbox warning light keeps coming on. Usual scenario is start car as usual, light comes on and either extingushes after a few minutes or stays on until engine is stopped and restarted when it resets and seems fine. Usually the car goes to the garage for diagnostics and shows no fault and garage recommend an oil change "just to be on the safe side", which cures the problem as if by magic.This fault is caused by water vapour from the atmosphere condensing in the gearbox and shorting one of the sensors, and is easily cured. Take the car for a longish run 30 to 50 miles and keep the gearbox in sport mode, this keeps the revs above 3000 and ensures that the engine and gearbox get hot. This will boil off the water and clear the fault - SIMPLES:) Using this simple process will clear gearbox faults 9 times out of 10 without resorting to expense.
Chris
I dont have a stepspeed but that sounds like a top tip for those who do, I wonder how many have been out of pocket because of this.
nice one
- a Guest
- Visitor
Replied by a Guest on topic Stepspeed gearbox warning light- Some advice
Posted 14 years 9 months ago #9897quick question, quicksliver, do you know where we can get gearbox oil, i was thinking about changing the oil soon but having difficultly in finding someone near where i live supplying it.
thanks
Replied by stamford on topic Stepspeed gearbox warning light- Some advice
Posted 14 years 9 months ago #98992000 MGF 1.8i SE Wedgewood
2002 MG ZS200 Trophy Blue
1999 Land Rover Discovery series 2 TD5
Replied by phil-hex on topic Stepspeed gearbox warning light- Some advice
Posted 14 years 9 months ago #9902stamford;9899 wrote: Guess a gallon and a bit of spirited driving is cheaper than a trip to the garage!
and a whole lot more fun :yesnod:
- quicksilver
Replied by quicksilver on topic Stepspeed gearbox warning light- Some advice
Posted 14 years 9 months ago #9904Depends where in Northumberland you are. Sometimes it is available at Halfords or Unipart stockistsbobscot;9897 wrote: thats for that, happened to me yesterday , timimg couldnt be better, good excuse to take car for a run this weekend.
thanks
- a Guest
- Visitor
Posted 14 years 9 months ago #9906i tried the local car parts place but they couldnt get it.
i will phone unipart tomorrow , thats a good shout ,
cheers
Replied by David Aiketgate on topic Stepspeed gearbox warning light- Some advice
Posted 14 years 9 months ago #9917Excellent advice, Chris.:yesnod:Quicksilver;9895 wrote: At this time of year there are a rash of Stepspeed owners contacting their local garage because the gearbox warning light keeps coming on. Usual scenario is start car as usual, light comes on and either extingushes after a few minutes or stays on until engine is stopped and restarted when it resets and seems fine. Usually the car goes to the garage for diagnostics and shows no fault and garage recommend an oil change "just to be on the safe side", which cures the problem as if by magic.This fault is caused by water vapour from the atmosphere condensing in the gearbox and shorting one of the sensors, and is easily cured. Take the car for a longish run 30 to 50 miles and keep the gearbox in sport mode, this keeps the revs above 3000 and ensures that the engine and gearbox get hot. This will boil off the water and clear the fault - SIMPLES:) Using this simple process will clear gearbox faults 9 times out of 10 without resorting to expense.
Chris
it's amazing just how many problems can be cured by a good drive.:bye:
- quicksilver
Posted 14 years 9 months ago #9941Especially with F/ TF they were designed to be driven hard, so dont take kindly to occasional use. I drive mine daily ice permitting, and can really feel its reluctance if its had an idle day or two.David Aiketgate;9917 wrote: Excellent advice, Chris.:yesnod:
Chris
Replied by Adam-Mgtf on topic Stepspeed gearbox warning light- Some advice
Posted 14 years 9 months ago #9962
