CVT gearbox issues
- croxalldog
- Novice MGer
My 2004 stepspeed box has, I think bit the dust. I can smell hot oil and the box is not generating much traction, its revving but going nowhere fast. Oil looks ok and its only done about 200m since the change (correct oil used). I am assuming the worst unless anyone has any suggestions.
I can get hold of a replacement box out of an MGF, I understand that these are the same. ( I assume that spares are very rare, and repair of the old would be difficult ). I was wondering if the subframe could be part dropped to remove the gearbox or if the entire frame has to come out, which looks difficult on the drive. By part dropped I mean remove fixing bolts from one side loosening the others and jacking up 1/2 the car so the the subframe swings on the remaining bolts giving me the clearance to remove the box.
Help please.
Help please.
by croxalldog
So few of us (myself included) here have any real experience with these boxes so you might be waiting a while for any useful info...
Sorry I can't be of anymore help and I used to rebuild automatic transmissions for a living..... even then I never had to encounter one.
Last Edit:3 weeks 5 days ago
Last edit: 3 weeks 5 days ago by Cobber.
The following user(s) said Thank You: croxalldog
There is some useful information on the Stepspeed auto box in the How To section of the forum. Also refer to sections on gearbox removal, engine removal etc. Several forum members have removed rear subframes on their drives so it is feasible. Use the search facility to find these threads as they will help you here.
by Notanumber
- croxalldog
- Novice MGer
I'm going to give it a go rather than write the car off. The body is in good condition.
by croxalldog
I think that is an excellent decision. The way to look at it is that every hour you now spend on it is another hour closer to having it back on the road. Every hour is a useful investment of your time.
Go for it and use this forum as a constant prompt, sounding board and agony aunt.
You are not on your own with this.
Last Edit:3 weeks 4 days ago
by Notanumber
Last edit: 3 weeks 4 days ago by Notanumber.
Ask Darren at Mgfntfbiz to see what he has by way of 2nd hand gearboxes. I've never had anything except fair prices and excellent service from him
by Notanumber
Have you got hold of another Stepspeed box or are you converting the car to manual ?
by Notanumber
Time to create page: 1.934 seconds
