Cost of engine rebuild...what should I do?
Replied by Airportable on topic Cost of engine rebuild...what should I do?
Posted 1 week 16 hours ago #208907If it were to be a valve stem oil seal, he & Claire would come prepared with a freshly refurbished unit to match your engine & when they leave in the evening your car will have everything miscreant item replaced & your MOT would be a forgone conclusion. Providing the catalyst is good & it’s been cooked at gas mark 70 after a hard run.
Bitz would sort you a good replacement though.
Replied by c13amb on topic Cost of engine rebuild...what should I do?
Posted 1 week 16 hours ago #208908Therefore I will be trying to sell it as is or break it up as it has many good parts on it that I will mention eventually when I get sorted. Disappointing as it is he reckons that the rot underneath may make the engine investment not worth while in 12-18 months.
Some attached pics of her🙁
Replied by R40MGF on topic Cost of engine rebuild...what should I do?
Posted 1 week 15 hours ago #208909There are many reasons why it could fail the emissions test but if you're not getting smoke from the exhaust then I wouldn't think that the engine was your problem.
A bad sensor or cat could be your problem.
Posted 1 week 14 hours ago #208913I acquired my tf due to the original owner not wishing to spend any more money on it. After minimal work it proved to be a great car.
The continuing depression in tf prices can lead to the vehicles dissolution (a gentlemanly euphemism for scrap) & just looking at the pictures might create interest in the wheels, four pots & discs. It wouldn’t take long for those items, If in good condition, to be more valuable as parts than if they were attached to a car for sale
I know that this is contentious, so don’t mutter your displeasure at my comments to yourself, become that “keyboard warrior” you always knew yourself to be & bollock me for my heretical thoughts, if you do wish.
Replied by Cobber on topic Cost of engine rebuild...what should I do?
Posted 1 week 13 hours ago #208914Most problems seem huge until you actually find what it is that has gone wrong, the trick is zeroing in on the source of your woes, now it's easy for me to say all this from the other side of the world, but it's a pity that I can't see the car for myself.
But blaming the head gasket with out any evidence, that it is the cause is a bit like blaming a broken leg on a heart attack, out of context , it makes no sense
the heart attack may have set in train a series of events that resulted in the broken leg, but without any evidence to prove it.....there is bugger all to link the two!
Which reminds me of something that happened here in Oz back in the 60's at the Bathurst endurance race, one of the cars had an obvious case of the engine doing an impression of a had grenade going off, with a huge cloud of oil smoke, oil all over the place and a nice mix of engine internal allsorts deposited upon the track.
The TV commentator interviewing the driver asked what had gone wrong? the driver replied dryly that the alternator fell off! The bloke from the telley was incredulous and asked how that could cause the the spectacle witnessed, the driver replied that the conrod let go, punching it's way out of the engine block, knocking the alternator off!
- generous_dad
Replied by generous_dad on topic Cost of engine rebuild...what should I do?
Posted 1 week 13 hours ago #208916I have a good relationship with a very reliable nearby garage who is happy to do work on our cars or just an MOT with the same customer satsifaction.
They even encourage me to do my own work on our cars.
My TF failed on emissions and it has an after-market "short" CAT.
My mistake was to present the car relatively cold. The water was up to normal but the engine itself was not.
The garage principal told me that many modles of car suffer from the same problem. They are fine when fully warm.
Could this cause help you pass?.......
Replied by Pharg55 on topic Cost of engine rebuild...what should I do?
Posted 1 week 13 hours ago #208917Please Log in or Create an account to join the conversation.
Posted 1 week 13 hours ago #208918Please Log in or Create an account to join the conversation.
Posted 1 week 13 hours ago #208919I've had genuine cats fitted only a couple of years ago with every possible conceivable item thrown at it..lambda sensors repeatedly.. all cleaners to try and clear up the emissions. The head gasket isn't the issue here it's the fact that the head needs to come off to diagnose anything untoward and replaced so there's best part of £700 before anything else!!
I haven't got anywhere to store it at home until another recommended party is able to look at it as I know it can take months due to their popularity.
As the garage said they are happy to do the work and I'm happy to pay for it if I thought it was a viable option but the rest of the car is going to need some sort of restoration following on from this and there comes a point when you have to weigh up your options!
Posted 1 week 12 hours ago #208922This is gutting but I need it gone before I really consider my next option!
Posted 1 week 12 hours ago #208923Now the rust etc is entirely another matter and I can't help you with that part of the decision from afar.
But do you intend to replace the car with another MGF/TF? if so I'd hang on to this one and swap over any desirable/better/new bits over to it's replacement. before unloading the current car. Yes I realise space may be a problem but it is a short term problem, that requires you to find away how to swing it.
It's not how many problems or how big those problems are, but how you go about tackling them that defines you.
Posted 1 week 9 hours ago #208926The rust is the problem as welding has been done for the last two MOTs so it's in the car now so the problem is do the engine work could be easy could be a right pain in the arse but then the car falls to bits in a couple more years and I'm finding it hard to justify the expense when the cars worth about £2k when fully fit!
I may be getting another MG possibly but not right away so the storage until I do may become a problem!
