Cost of engine rebuild...what should I do?
Replied by c13amb on topic Cost of engine rebuild...what should I do?
Posted 1 year 9 months ago #208928Please Log in or Create an account to join the conversation.
Replied by Cobber on topic Cost of engine rebuild...what should I do?
Posted 1 year 8 months ago #208929"Keep calm, relax, focus on the problem & PULL THE BLOODY TRIGGER"
Replied by Airportable on topic Cost of engine rebuild...what should I do?
Posted 1 year 8 months ago #208932You can however travel to a test station for examination provided there has been prior arrangements made & the distance is commensurate with your location.
It would be nice to have a drive to Thurso, or possibly Bodmin, for an MOT but you might have to defend your actions in court if apprehended.
So although the powers that be seem to want to throw us back to the dark ages, with all the incivility that that entails, we can still take our cars for an MOT without up to date paperwork, providing prior arrangements have been made. And so Cobb’s we’re not (yet) as uncivilised as you intimate.
The fact that as you dutifully take your car for their test, you will most probably pass any number of cars without a ticket. This is life in Great Britain during the times we find ourselves in.
Replied by D4KGP on topic Cost of engine rebuild...what should I do?
Posted 1 year 8 months ago #208934Please Log in or Create an account to join the conversation.
Posted 1 year 8 months ago #208935In the less civilised states that demand an annual inspection so long as the rego is still current it is fine to drive the car to the RWC station and to a place of repair if needed in order to bring the car up to RWC standard, If the cars rego has lapsed or the car is unregistered you need to get a temporary permit from the rego authority (this can be done online) which allows you to only drive the car to various repairers as required, to also present the car for it's RWC inspection and the the rego office there is no limitation on how far but you must use the most direct route and you must not use any tollways, There is also a restriction on the time of day, it must be during daylight hours (probably in case the lights aren't working properly)
I'm fortunate to live in the state of Victoria which has no annual inspection requirement, a car only requires an inspection when it has no current rego (even then you have a 3 month grace period in which you cant use the car till you pay the renewal but you still don't need an inspection) or the car is either unregistered or you are transferring the ownership then you require a RWC (Road Worthy Certificate)
It's interesting to note that there is no appreciable difference in accident rates between the states that require annual inspections and those that don't require any such nonsense.
There is a constant running lobbying battle between the VACC (Victorian Automobile Chamber of Commerce. car dealers and repairers)Â and the very connected and very politically powerful RACV (Royal Automobile Club of Victoria)Â The VACC wants annual inspections (No vested interest there....not many!) and the RACV won't have a bar of it.
Disclosure note: I did used to work as a contractor for the RACV and was a member of the VACC, so as a result got to watch the antics from within both sides up close.
Replied by TA22GT on topic Cost of engine rebuild...what should I do?
Posted 1 year 8 months ago #208940If you go for an MOT and your existing certificate is still valid and the car fails the test, the existing certificate is null and void. Glyn.
This is correct.
Â
Posted 1 year 8 months ago #208941"Keep calm, relax, focus on the problem & PULL THE BLOODY TRIGGER"
Posted 1 year 8 months ago #208944In consideration, a tester could hardly allow a vehicle, still in MOT, back on the road, if the arse end is dangling on the road.
I will study the regs’.
Posted 1 year 8 months ago #208945If this is correct, then I stand corrected & apologies for misleading.
I too used to think that because you can test a month before your MOT runs out if it failed you still had the remainder of time left but the Tester said No.
If it fails it has no MOT regardless of when the original runs out. Bummer!!
Â
Replied by Pharg55 on topic Cost of engine rebuild...what should I do?
Posted 1 year 8 months ago #208952Please Log in or Create an account to join the conversation.
Replied by R40MGF on topic Cost of engine rebuild...what should I do?
Posted 1 year 8 months ago #208953- your current MOT is still valid
- no ‘dangerous’ problems were listed in the MOT
Posted 1 year 8 months ago #208955Please Log in or Create an account to join the conversation.
