MGTF OBD Socket Pin out
Hi all,
Hope you are well, been a while since I've worked on the car let alone been on here.
I'm hoping someone can help me out.
Does anyone have a pinout diagram or details for the TF 135 MEMS3 OBD Socket. It appears that the only pins which are wired in the socket are pins 1,3,4,7,13 & 16.
I've had a look in the workshop manuals/RAVE drawings and the drawings for the diagnostic socket are a little iffy if that makes sense.
Any advice or help would be greatly appreciated.
Many Thanks,
Stu
Many Thanks,
Stu
by MGSED
Only info I can find.
Pin Use
2 J1850 Bus+
4 Chassis Ground
5 Signal Ground
6 CAN High (J-2284)
7 ISO 9141-2 K Line and ISO/DIS 14230-4
10 J1850 Bus
14 CAN Low (J-2284)
15 ISO 9141-2 L Line and ISO/DIS 14230-4
16 Battery power
If that helps...
Pin Use
2 J1850 Bus+
4 Chassis Ground
5 Signal Ground
6 CAN High (J-2284)
10 J1850 Bus
14 CAN Low (J-2284)
16 Battery power
If that helps...
Many thanks David, Appreciated.
I've had another look through the drawings and have managed to find one with the pins noted above. I was getting a bit confused (doesn't take much) but all ok now. Appreciated thank you.
by MGSED
Time to create page: 0.363 seconds
