MGTF OBD Socket Pin out
  • MGSED
  • Apprentice MGer
  • Apprentice MGer
MGTF OBD Socket Pin out was created by MGSED
Posted 1 year 6 months ago #210773
Hi all,
Hope you are well, been a while since I've worked on the car let alone been on here.
I'm hoping someone can help me out.
Does anyone have a pinout diagram or details for the TF 135 MEMS3 OBD Socket. It appears that the only pins which are wired in the socket are pins 1,3,4,7,13 & 16.
I've had a look in the workshop manuals/RAVE drawings and the drawings for the diagnostic socket are a little iffy if that makes sense.
Any advice or help would be greatly appreciated.
Many Thanks,
Stu
by MGSED
Replied by David Aiketgate on topic MGTF OBD Socket Pin out
Posted 1 year 6 months ago #210781
Only info I can find.
Pin Use
2 J1850 Bus+
4 Chassis Ground
5 Signal Ground
6 CAN High (J-2284)
7 ISO 9141-2 K Line and ISO/DIS 14230-4
10 J1850 Bus
14 CAN Low (J-2284)
15 ISO 9141-2 L Line and ISO/DIS 14230-4
16 Battery power
 If that helps...
  • MGSED
  • Apprentice MGer
  • Apprentice MGer
Replied by MGSED on topic MGTF OBD Socket Pin out
Posted 1 year 6 months ago #210813
Many thanks David, Appreciated.
I've had another look through the drawings and have managed to find one with the pins noted above. I was getting a bit confused (doesn't take much) but all ok now. Appreciated thank you.
by MGSED
Time to create page: 0.371 seconds
