Guess what - HGF
But please make sure that whoever you get to do the job is up to speed with K series engines.
From everything I have read it wont cost any more than using a knockabout corner garage but the job will be done right by experts and there is no risk it will need to be repeated again in a few months due to a mechanic failing to measure the cylinder liner height so picking the wrong gasket.
There is no way of really diagnosing a warped head without removing it and putting a straight edge across it, you can use a compression test, a cylinder leak down test, a sniff test or a coolant system pressure test to diagnose a failed head gasket, and they can indicate other possible combustion chamber problems such as a cracked or warped head, a unseated, cracked or porous cylinder liner, but the only way to know how bad the problem is, will require removing the head to be sure.
The guy is about 15 miles away - I'm assuming it wouldn't be a great plan to drive the car to him
There is still a semi-local expert, but he's about 15 miles away. So the question is... I've only driven maybe 20 miles since I noticed the problem. Would it be very inadvisable to drive it slowly to him, with maybe an hour's break in the middle, or would this be seriously risking making things worse?
Ta
It maybe worth having a look at Rough Luck Racings web site.
I know that they used to get around quite a bit, UK wide and most of Europe.
- generous_dad
