[SOLVED] Remote lock/unlock
- a Guest
- Visitor
It's rather frustrating walking away from the car, trying to lock it, realising it's not that good and walking back
If you undo the passenger side kick panel (with the light in it.) You will probably see a yellow wire coiled up, this is the aerial. If you straighten it out, it should increase the distance.:yesnod:Tomm;9957 wrote: Basically had this problem since I bought the TF.. the remote lock only works if I'm quite literally stood right next to the car. I've replaced the battery in the fob and it hasn't made a difference. What other checks can I make to sort this out?
Although I had to open the thick loom to find the yellow wire.
- a Guest
- Visitor
David Aiketgate;9958 wrote: If you undo the passenger side kick panel (with the light in it.) You will probably see a yellow wire coiled up, this is the aerial. If you straighten it out, it should increase the distance.:yesnod:
Thankyou very much *adds to 'to do' list for tomorrow* as well as oiling up some stiff nuts :dc:
Mmm, stiff nuts, eh?:whistle:Tomm;9963 wrote: Thankyou very much *adds to 'to do' list for tomorrow* as well as oiling up some stiff nuts :dc:
- a Guest
- Visitor
Will cover them in shotgun oil tomorrow and try again
