2009 MGTF immobiliser issue
2009 MGTF immobiliser issue was created by GN09MGU
Posted 2 weeks 6 days ago #224044
My car is currently disabled by the immobiliser. Probably the fobs are out of sync. I have replacement fobs on order, and I have a PSCAN (which I have never yet used). I note that the PSCAN web says that fob programming has been tested on MGFs, but does not mention TFs. Will it work on TFs? Or would people recommend a KMaps ECU instead, as I understand this removes the immobiliser function (as well as giving the intended performance upgrades)
by GN09MGU
Replied by Roverlike on topic 2009 MGTF immobiliser issue
Posted 2 weeks 6 days ago #224046
If you ordered correct Pektron oval fobs with bar codes which are needed for programming them to Pektron alarm box, then PScan can code them.
Use of KMaps or SAWS is your choice depending what you want to acomplish.
Replied by GN09MGU on topic 2009 MGTF immobiliser issue
Posted 2 weeks 6 days ago #224048
Thanks. I read in some places that a working fob is needed in order to program a new one. Is that true?
by GN09MGU
Posted 2 weeks 6 days ago #224049
One working fob is needed in order to unimmobilise the Pektron alarm system if it is not already unimmobilised.
Point is you cannot access the Pektron alarm system in order to program new fobs if Pektron system is in immoblised state. You do not have EKA code unimmobilisation as an option since your car is 2009. If this happens to be your situation then maybe best for you is to contact Paul @  https://www.technozen-electronics.co.uk/  and see what options you have.
Replied by Cobber on topic 2009 MGTF immobiliser issue
Posted 2 weeks 6 days ago #224050
There are quite enough things to immobilise our cars without the damned ECU joining in the fun, just for the bloody devilment of it...........Get the ECU remapped, lose the idiotic immobiliser function and pick up a few extra horsepower whilst your at it......win win!
Last Edit:2 weeks 6 days ago by Cobber
Last edit: 2 weeks 6 days ago by Cobber.
Posted 2 weeks 6 days ago #224059
KMAPS tell me I would also need to earth an output on the Pektron unit, as the immobiliser stops the engine cranking, as well as sending a signal to the ECU. But I am starting to think the issue might be the micro switches in the door lock - if I open and close the lock a few times the fault clears.
by GN09MGU
Posted 2 weeks 5 days ago #224062
Do you want to say if you lock and unlock the car with the key then after some time you can use the fob and after that you can start the car? If this is the case then I do not think you have problem with your fob, but the problem is somwhere else, like ground connection or similar. If this is the case have you checked boot wiring that it is not broken?
Posted 2 weeks 5 days ago #224070
It was a bit erratic, but I am now more or less convinced that the problem lies within the door locks - if the car won't start, I can persuade it to by manually operating the lock button on the driver's door up an down a few times.
by GN09MGU
Replied by pscan.uk on topic 2009 MGTF immobiliser issue
Posted 1 week 15 hours ago #224400
Do you have a working fob now?
Time to create page: 0.386 seconds
