GEMS Landrover / Rangerover P38 V8 ECU
Introduced in version
041F
of pscan.
Reads both OBD2 error codes and Landrover proprietary codes.
Reset error codes.
The live data is the same as data as that exposed to an OBD2 tool as this appears to be what a factory tool does.
Learning of EMS code from 10AS (tested) and BECM (untested).
Specifically this puts the GEMS ECU into a mode such that after a power cycle it will learn the next 10AS / BECM code that it sees, it is not immediately learned.
Testing of immobiliser status.
This appears to be of use only on the first power cycle that an EMS is learned following the above EMS learning mode is engaged.
Once an EMS code is learned and then power cycled again the status is not useful.
Resetting of adaptations is not yet implemented.
Output actuation is not yet implemented.
Reset error codes.
by pscan.uk
The following user(s) said Thank You: All_Mighty_Bear
Why was the adaptation reset (LTFT) not implemented, I think it bothers a lot of P38/Disco owners... Otherwise Pscan is great !
Last Edit:1 year 8 months ago
by KDB
Last edit: 1 year 8 months ago by KDB.
Replied by pscan.uk on topic GEMS Landrover / Rangerover P38 V8 ECU
Posted 1 year 8 months ago #209685
okay I'll have a look into it
by pscan.uk
Perfect !
Last Edit:1 year 7 months ago
by KDB
Last edit: 1 year 7 months ago by KDB.
Time to create page: 0.374 seconds
