Software version 0420
This version adds tuning capabilities for the MEMS1.9.
They have been tested on an ECU in our lab but not on a running car.
Use this feature with extreme caution.
Details of the previous version are here .
God knows what I'm doing to the engine
but it seems to be holding together ok.When I get a chance I'll put the pscan on with this new update and see what that is showing.
Robin ![]()
Thanks
- sworkscooper
John
https://www.sevener.fr/fichiers_articles/Manuel_sur_ECU_Rover_MEMS.pdf
Some MPI engines have a knock sensor and so I guess are "self tuning" to some extent. Is this why they cannot be tuned by a diagnostic tool?
We ran my sprint car, "Project Shed", a 1996 MGF with a 1.8 MPi engine running MEMS1.9. Not quite standard: it has R140 cams, a 52mm throttlebody (because I had one spare), a K&N panel filter, an MGF Centre 4-2-1 exhaust manifold and a Trevor Taylor single exit exhaust.
Advancing the ignition gave an additional 2 bhp, but there was little to be gained from advancing beyond 3 degrees.
The K-series is over-fuelled. By knocking back on the fuelling around 60 units (not sure what those units are) gained another 3 bhp
Went from this:
To this:
Because the settings only alter the "open loop" look up table and not the "closed loop" map, there is a little kangaroo'ing at very light throttle openings at very low engine rpm in low gear/ low road speed situations. But other than that, everything is gravy
The acceleration is much smoother, pick up is very clean, and throttle transitions under all other circumstances are perfect.Generally I am very pleased and all it has cost me is an hour's rolling road time. And I would recommend that you do use a rolling road if you really want to optimize the power/torque and establish the "safe limits" because both T4 and pscan will allow you to advance the ignition too far and lean off the fuelling way too much. That said, you can probably play with the settings (say to +2 degrees ignition advance, -30 fuel) within a reasonable safety factor with 60+% of the benefit...
I wonder what effect this will have on emissions at MOT time. I may have to take my laptop with me to the test in order to reset to default, or set it to default and then put it back afterwards.
Thanks once again for your efforts (and Phillip's).
Robin ![]()
1. The test is done at steady-state rpm, and thus the engine is using the "closed-loop" map; we're altering the "open-loop" map here
2. The changes we're making are modest: the most likely impact of the changes we're making are likely on nitrogen oxides - and these hopefully will be contained by the catalytic converter.
Obviously I don't want to debug how to use a competitor tool so enough said about that.
pscan on the other hand has very clear rich/lean and advance/retard buttons and the screen tells you what you have set compared with default.
Also pscan talks to every ECU on your MG Rover (well most of them anyway) and you get some proper customer support too. Just buy a pscan
