Horn Test Failed
- a Guest
- User
If I turn the key the car immobiliser is on - I bought the unit to program the new fobs I have.
Cheers
Dave
Which car is causing the problem.
What other tests have you done on the horns?
- a Guest
- User
Plugged the unit in and everything went well but then running the horn test failed. I tried it with the ignition on and off.
The horn doesn't work from the horn button either but I was wondering if the immobiliser prevents this?
Cheers
Dave
Try earthing them.
Try applying 12v to one side of the horns and earth the other side.
- a Guest
- User
I've also found a page detailing testing the horn so will be following this through - http://www.apttony.co.uk/Servicing/HornFailure.html
Cheers
Dave
You will need to open the door to trigger the alarm, an alternative is to have the boot open when you set the alarm, leave it for a couple of minutes and then pull the bonnet release which should set the alarm off.
To separate the steering column cowling there are 3 screws underneath, then it is clipped together.
- a Guest
- User
1) Check the fuse - Doh!!
Problem solved.
Yes I am that kind of idiot.:bang:
Anyway I now have a key fob that actually works on the car. Car doesn't start but hey, can't have everything.
- a Guest
- User
