Pektron failed?
Pektron failed? was created by Ludo.190
Posted 7 years 8 months ago #188503
Hi!
I would first like to thank Philip for his job
My 2005 ZR 160 Start and cut immediately
Immobilizer seems desable (the led is off)
I can hear the pump arm when I turn the contact
I learned on a forum that it is possible that my Pektron SCU can be involved and prevents me from starting
would there be anything I can do so I can restart this car with my Pscan tool? Maybe a new learn on mems3?
Thank you!
Replied by talkingcars on topic Pektron failed?
Posted 7 years 8 months ago #188505
Have you used the pscan to read the Pektron ECU to see if there are any faults stored?
Replied by Ludo.190 on topic Pektron failed?
Posted 7 years 8 months ago #188506
Thank you for your answer ,
Unfortunately the car is not at home, in a few days I'll be able to go see it with my PSCAN, I hope I'll be able to start it!
Replied by pscan.uk on topic Pektron failed?
Posted 7 years 8 months ago #188507
The first thing to do is to log into the Engine ECU and check the immobiliser status.
Posted 7 years 8 months ago #188509
Hi!
I went to see the sick car!
In immobiliser status--> Correct EMS code received
i have try to reprogramming my fob but the car doesn't start more
Replied by sworkscooper on topic Pektron failed?
Posted 7 years 8 months ago #188510
It will be impossible for you to program the fob unless you have the bar code that the fob had when it left the factory . :nonod:
I had a similar situation with my TF earlier this year. I ended up removing the Pektron SCU and sending it and the fobs to a guy called Paul Brown who runs Technozen and he specialises in this type of problem .
John
www.Technozen-electronics.co.uk
Last Edit:7 years 8 months ago by sworkscooper
Last edit: 7 years 8 months ago by talkingcars.
Posted 7 years 8 months ago #188511
You should be able to start the car using the EKA
Posted 7 years 7 months ago #188512
335/5000
Unfortunately I did not manage to validate the code EKA with the key:
hold 5sec lock
the alarm is running
unlock first digit
lock second digit
unlock third
lock the fourth
the LED stays on and the alarm sounds a bit
Is the procedure the same for LHD and RHD cars?
Or is it related to my startup problem?
Posted 7 years 7 months ago #188513
What happens if you try to log into the Pektron with your pscan?
Posted 7 years 7 months ago #188515
I can do it well, I can see the values
Posted 7 years 7 months ago #188516
Ludo.190 wrote: Is the procedure the same for LHD and RHD cars?
Try turning the key the other way for the first turn.
Replied by Rob Bell on topic Pektron failed?
Posted 7 years 7 months ago #188523
And yes, procedure is the same for both LHD and RHD vehicles :)
Time to create page: 0.419 seconds
